whitneyj
- Mayville, WI
That's actually the exact same thing I did, while I was working half heartedly on the rebearing of the hpd44 I also ran some 3x3x3/16 from the front spring hanger to the bumper. Funny. . . I won't be running leaf springs up front, kind of wish I had for simplicity's sake. Did a couple things tonight, nothing to special, I only had an hour or so to use. But I burned in a couple welds for the relocation brackets. I already primed them when I took the pictures.
I ended up not taking them to work for my buddy to weld, I just preheated the radius arm with a small soldering torch and burned them in with the old 110V Clarke.
After they were cool I blasted them and the coil buckets with some primer after running a wire wheel over em.
That's about all I have tonight. Tomorrow I'll be putting everything together and getting ready to build the trackbar and mounts and the drag link. Not to sure yet how I'll be going about the trackbar. I may build the draglink first, then I'll have a length and angle to go off of. Once I get those built then it'll just be plugging away at the long list of little things.
P.S. sorry for the crappy pictures, I'm camera illiterate.
