O-Gauge Steamer
- Colorado Springs, Colorado
Why yes. Nippondenso part #: DN13341NA200
It is 200 Amp rated unit. Min produces a solid 190 Amps. For fusing, I installed a 200 Amp fuse at the front of the PDC along with a replacement wire from the Alternator to the fuse. There is a thread, somewhere here, that documents the installation of the fuse.
Works just fine.
In the past, I have attempted to use reworked alternators that claim to be high output units. Without fail, poor results at idle is what I got. This time, I bit the bullet and purchased a new part that is properly assembled.
You can Google the part number to find online suppliers. Expect to pay mid $300s for it.
Hope this helps.
After thought... If the new alternator does not come with the "small" pulley on it, swap over the pulley from your existing unit.
This part can be use on:
(1998-97) Dodge Dakota 2.5L
(1998-91) Jeep Cherokee 2.5L, 4.0L
(1992-91) Jeep Comanche 2.5L, 4.0L
(1998-92) Jeep Grand Cherokee 4.0L
(1998-91) Jeep Wrangler 2.5L, 4.0L
Works just fine.
Hope this helps.
