Have you considered the o/h console from a conversion van? They are very common in the junkyards, and most of them still have the switches in the consoles. You can get a wide variety of styles and materials. As for the install in your '90, I had to put a strip of metal up above the headliner in my '88 to help hold the consoles' weight, and to make it easier to mount. I even found a set of 4 switches that are amber, AND had circuit breakers instead of fuses, like most of those panels use. Also, above the headliner, just watch for the wires for your lights, or console if you have one, nad be careful of making too big a hole in the headliner. When you run the wiring, you can go behind the trim plate on the driver's side of the A-pillar (2 screws behind the little plugs), and then along the front of the headliner. Be careful not to pull it down too hard or far, otherwise it will break/tear. You may have to take off the trim across the top of the driver's door to get the liner to come down enough to work the wiring into place. Hope this helps. Ren
