joe_peters
- Grants Pass, OryGun
wow!!! put the plugs back in after switching the two lines at the map sensor and on block and she fired right up!!!! I think the rich problem may be fixed as well! Thanks a ton guys! anyone know what rpm she should idle at? RUNS TONS BETTER NOW!
Don't forget to check those injectors! No need to loose a ride to a fire.
If they are the original style, you can replace them with Ford orange-top injectors from most any 3.8 and up Ford vehicle. The stock are 18.6 lbs and the Fords are 19 lbs, they plug right in, and they have 4 small holes instead of one large fat hole as the stockers. About $20 at a salvage yard.
