OK, so here is what ARB said to me......Use a bigger hammer. WTF! are you kidding me. Use it to force out the pin. Basically the only way for that little retainer pin to have broke is that one or both of the gears has seized up on the Cross Pin, thus forcing it out with a hammer. This can be due to a bent axle shaft, improper setting of the locker and all sorts of other things. He said if I cant get it out worst case it that I have to torch out the gears and pin and purchase a new set...at about 250 bucks for those parts, and then if the cross pin has egged out the holes on the case housing itself Im into it some more cash.....might as well just buy a new locker at that point and have someone kick me in the balls cause I will be thoroughly screwed since I dont have the scratch to get one. Looks as if I get to do some MC Hammer time :banghead:
