88manche
- Portland, Oregon
lowrange2 said:36s? that's it?
Eh. Anything bigger wouldn't really fit on the trails around here.
85xj4dr said:Go Dana 60 front and rear, 36'' maxxis creepy crawlers. 5.13's, lockers front and rear.
mattyj said:Make that 37" creepies...... they dont make 36's
You avatar, sir, is DEFINATLEY not a Jeep. But I ain't complaining.
tayman said:yeah, you got a larger pic of that???
1986XJIan said:I'm sorta having the same problem. I currently have 35's and my choice is to upgrade the D35 or downsize the tires.
soxyfarmer said:I ran 35's on an aussie locked D30 and sheared my ring gear. Everything else held fine but I think that 35's put a LOT of stress on that little axle. My opinion is, it's an inevitablity that you'll break stuff with 35's and a D30 unless you spend some serious coin polishing it.
(but if you decide to upgrade to alloys, you should buy mine in the sierra for sale section! wink wink)
tayman said:just outta curiosity, what was your gearing? won't slightly higher gearing lessen your likihood of breaking stuff?
I had 4.88's. Actually, the lower geared (numerically higher) the higher your chances of R + P failure. Wish I would've known that before!
tayman said:see, that's what I said if you read closer... I know a little about what I'm talking about... haha.
I was thinking of doing 4.56's, so I guess that would make it a LITTLE less likely to break stuff... where would that put me in relation to stock gearing?
hah, I like it... basically my philosophy!Run what you want, if it breaks it needed replacing anyway. -Murphy's Law
