88trailcrawler
- OC SoCal
If your going 33x12.5 you'll probably have to trim or at least boost your lift a bit with spacers/shackles.
Research rim set back before you buy.
My 88 (I think they have a little bigger wheel wells) cleared 33's with a RE 3.5 kit for street driving. With a spacer/shackle boost it will tuck and rub the flares on the trail. Both would have hit front bumper returns that I had already trimmed off.
Consider 10.5's. will allow for more back spacing and/or clearance from control arms and springs. They will be a little lighter and allow for a narrower/lighter rim.
I am on 33x10.5 on stock rims. RE 3.5" kit with 1" shackles and 2" coil spacers.
I tuck and rub at full flex with stock flares. And I rub control arms at full lock.
I suggest you get the lift installed and sorted out first. Then you can measure your clearance and make a tire/wheel decision, then evaluate your driveline vibes
I didn't have vibe problems, but did the SYE when I did my axles mainly so I didn't have to worry about the SY dropping out when flexing.
Remember: SYE will add drive shaft. Tires over 31 will be best with regear............it never stops.
If your just looking for a more aggressive stance for a DD/fire road explorer, I would not go past 3.5" or 31/32". There is a lot of better places to upgrade and improve that you can benifit from.
