xjproject
- Everett, Washington
About a week ago I noticed some noise comming from the steering. AFter checking it out I noticed that the trackbar looked loose. I had a friend turn the steering wheel while I watched the TB. I noticed tht bolt that attaches the tie-rod end of the TB to the frame seemed loose. I tried to tighten the bolt with no luck, I even tried an impact still no luck. When the steering wheel is turned left and right the bolt moves as well. The bolt is tight to the TB but seems loose to the bracket. Any Ideas??? The lift is a Rubicon Express 3.5 under a year old.
