Boost_Retard
- Vancouver BC
is the 17.313" YJ rear brake hose the longest factory rear brake hose that i can use on my cherokee when i install my OME 3.5" lift?? 2.313" longer than my current 01XJ rear line, if thats long enough i will go with this line, or with your help, track down a slightly closer to 3.5" longer factory line..
PS: anyone know off hand if there is a difference between ABS or non ABS rear factory lines? it looks like the 95 wrangler YJ 17.313" non ABS line is just a longer version of my 2001 XJ 15" line with ABS, it looks like it should do the trick, if anyone knows for sure please fill me in and i will place my order.
thanks
Cale
thanks
Cale
