NorCAL_XJ11
- Redding CA
When you get bitched at by every girl that gets in your jeep because it got their clothes dirty.. And they wonder why you never called them back
you know you can multiquote right? :spin1:
hit the button that says "+ on it right next to the quote button for every post you want to reply to. Then when you are done reading, hit the post reply button and you'll have them all in one spot.
You know it's an XJ when you spend the first twenty minutes of a drive after a two week (or more) rest wondering which of the shakes, rattles, and noises are normal and which may be a sign of impending doom.
...when you fix the EGR valve with a pair of scissors and two screws...and it suddenly runs better than new.
...when you fix the used one the previously owner unloaded for cheap with a $13 used power steering pump and 2 screws.
...when every XJ in the family's Check Engine Light is permanently on but they all run fine.
...when the passenger can sometimes put down the power window, but the driver always had to put it up.
...the rear overhead light refuses to come on, but if left in the on position will drain a battery stone dead in under 6 hours.
...your left turn signal light is permanently lit while driving but the turn signal works fine.
...when your rear hatch shudders so violently at 60 mph you're afraid the glass will blow out so you've resolved yourself to drive 58mph even on the freeway.
Your list of procedures to remove the oil pan start as; 1) remove front axle.
Scratch that, step 1 is lift jeep
...when you fly 400 miles to pick up an XJ that has been sitting in someone's driveway undriven for 4 years, and driving it back is your only option, through 100+ degree desert heat, because it is totally stock, straight, rust-free and only has 217K miles, and knowing that whatever may break or fail you can rig something to get you home.
