yikes
- SE Wisconsin
DAMN, that is a nice underside :shocked:
What are the options for someone with an aftermarket bumper that don't weld so well ?
So basically the list of advantages for this system is:
1) Lazy people don't have to get out to disconnect their sway bars
2) It forces the rear to flex more, since the front is some what inhibited, creating a slower body roll when the XJ makes a quick drop?
That's quite an expensive setup for that...
I installed polly bushings on my standard bar and run JKS links. Now its pretty obvious the rear will move more, since the front is restricted, but I don't see how lifting a tire sooner inspires confidence... or am I missing something?
So I finally wheeled on the anti-rock, it does limit the front flex somewhat, but it also forces the rear to flex more. It keeps my jeep much much more stable on rocks and off camber situations, before with my long arms the suspension would unload quickly causing a sideways shaking of sorts. With the anti-rock the unloading is slowed way down and it creates a much more stable ride on the trail.
-Alex
You are missing quite a bit, actually.
Eh, I wouldn't say the stock bar allows for a great amount of flex. I could really tell when I had one connected vs disconnect. And I definitely wouldn't say that they are for lazy people who don't want to get out and disconnect. It was a complete pain trying to disconnect and reconnect, since rarely was I ever on flat ground to be able to take them off.
The main thing is that you will get better traction. For instance, when your disconnected and at "almost" full droop your tire has pretty much no down force. So even know it might be touching something, it wont want to grab it. With a Antirock sway bar that allows it to flex down "all the way to full droop" (the correct way for an antirock to work) your getting that extra down force that you need in order for that tire to grab. Plus many more benefits but the one above I think is the main reason for it.
Oh yeah, I can definitely tell its still connected, I'm just saying that if I leave it connected, I can still get a decent amount of flex, no where near full droop, but not completely hindering.
I get it now though, I was under the assumption this was a solid stock material that completely removed roll/sway. So how far could these bars be twisted opposite? Say you had the bar sitting flat on the ground, both ends parallel (forget about the links for a moment) and you twisted them, if you could by hand, in opposite directions. Can you over twist them?
