2000bluexj
- Mass
Exactly what I asked. Was there different sizes available for the parking brake shoes? the rotor I have doesnt fit over them.
So one could get pre-loaded calipers for a 2006 liberty from rock auto:
A-1 CARDONE Part # 164755B {[Caliper w/Installation Hardware & Pad] Reman.}
Rear Left; Original Equipment Phenolic Piston;Ceramic Pads for $89.79 each
and
A-1 CARDONE Part # 164754B {[Caliper w/Installation Hardware & Pad] Reman.}
Rear Right; Original Equipment Phenolic Piston;Ceramic Pads for $89.79 each
and
rotors:
RAYBESTOS Part # 780134R {Professional Grade; Outside Diameter 11.22" / 5 Bolt Holes /Solid} Rear $30.79 each
and then find the backing plates at a junk yard or wherever and use either liberty soft lines, ZJ soft line and the e-brake and you would be good.
So you could do it with mostly new parts for around $275 or so? Is this right?
TIA
would this swap work on a 88 xj with a dana 35?
Explorer Cables DON'T work. They are too short, just barely though only a couple inches. I have a brand new set in my living room that I can verify DO NOT FIT. ZJ's are too short as well, at least one side is. I'm wanting to see if KJ cables will fit, but I'm afraid to order anything else unless I know it will work.
Right now I'm thinking about cutting the mounting points on the body off and moving them back about 6" and extending the bracket from the handle with a piece of threaded rod. This may be impractical if you don't have a welder though. As no one in my area carries KJ cables, I'm having to get them from RockAuto, so that's my hesitation. The local driveline shop that makes cables can't do the Ford style rears, or I would have just got custom length cables made up for it by now.
B.T.W. This is a stock height 1995 Sport, so there isn't any issues from a lift
One more thing, the older XJ's have a different mounting for the parking brake cable compared to the newer ones. The pre-1996 models are equal length, I think the newer ones have the equalizer offset to the driver's side. I will have to crawl under my roommate's 2000 to confirm this tomorrow.
