Dr. Dyno
- Al Ain, UAE
Ronbo said:The history of the V8 doesn't just revolve around short stroke high rpm engine architecture. I grew up in an 'Olds' family, 4.125 bore/4.250 stroke, it was all about torque.
Oh I know about the V8 not being only short stroke high rpm, and your Olds is a good example of a low rpm torquer.
Ronbo said:Around here, rpm gets my Jeep up the mountains. 225 ft/lb doesn't cut it. A stroker would give me plenty more torque at an rpm my Jeep just doesn't spend much time at.
Actually, my 4.6 stroker makes subtantially more torque than my old modified 4.0 but the biggest difference is from 1000-4000rpm. Unless your Jeep spends most of its time above 4000rpm, you really will notice the extra torque of a stroker and find yourself using a higher gear to climb the same hill.
I've had mine on the dyno; 198rwhp @ 4650rpm, 254rwtq @ 3550rpm with at least 90% of maximum torque available from 1600-4600rpm. That's about 30% more rear wheel HP/TQ than your average plain vanilla 4.0 XJ.
