Fram may have looked poorly in the cut-up study but if any filter is made for a specific vehicle and used on that vehicle and the motor suffers an oil related failure then the filter company is on the line for the results. In other words search all you want you wont find many failures due to bad oil filters correctly fitted to a vehicle. The only real time it would make a difference is most likely if you knew you were someone who knows they should change their oil at 3000, 5000, whatever but always forget and may not change it for 10,000, etc.
Sarge
