McQue
- Plainville, Connecticut
I have heard of electric dipsticks that keep the oil warm...not sure how well they work as I have never used one...a search on Google shows they still sell them..
The idea's really simple: warm the engine and it will start more easily. That is literally it.
I've never seen one installed. Where on the block does the OEM block heater connect?
I mounted two inferred spot lights on a long board that will slide under the Jeep. They are on a timer and general kick in about 2-4 hours before going to work.
What's good about this is they will heat everything under the hood. Battery, oil, block. In the sub 0 I may cover the hood with a blanket too.
They can also be use on any car they will slide under. If you use the smaller bulbs and a thinner broad it will fit under many cars.
Do you leave them plugged in all day or just a few hours before you leave?
I'm installing one. I doubt I will use it much right now as I don't think my apartment complex would be too happy about that, but I think I could use it at work during the day.
