Ah.........now, we're getting somewhere.
If you put a dropped pitman arm on, your tierod and trackbar will now be at different angles. Your handling will suffer, in particular, you can expect to experience some bumpsteer as a result.
You're referring to the stamped and laminated sway bar link mount, correct? Consider relocating those a couple of inches higher, rather than a dropped arm. Yes, it's more work.
