the vacuum gauge read a steaqdy 16-17 when i had it hooked up. left it on there for@5 minutes, which is why i already stated i dont think it is an exhaust problem. from start to finish, 16-17in of vac.
i also highly doubt, as i said before, a head gasket.
i did say how to run the compression test, and how to check for a valve or ring problem if the compression is low at number 1 cylinder.
johnathan, dont feel stupid for not knowing what the cat etc was mate, we all had to learn one time! i dont see the exhaust being a problem, it will sound like it does as soon as the motor has an issue, not sound like that because there is a blockage in the exhaust! an uneven exhaust sound is either an aftermarket cam or an issue with the motor not running smoothly.
just my .02...
martin
