BRIANHO13
<- Yum Chocolate
- Spring, TX
I need to load my jeep on the trailer.
Put in new t-case- DONE
Regear front
Make sure its not gonna explode
Fix CB- In progress
Put new reflector housing on my broken lightforce- 5 minute easy job
New exhaust- looking
Drive to Byron's to get my other driveshaft- Working on this
Im hoping to make it this year. If so the jeep needs.
Drivers floor pan patched Might not happen
Reseal the front axle Turned into Pinion bearings and axleshaft seals Still need to do
Front Ujoints Done
front brakes Done
Cb work
LOF
The Maybe list
Front axle brackets Ordered
lower control arms
Drivers window regulator
Already fixed.
Tailights and turn signal wiring
-Tow vehicle capable of getting there and maybe back if I'm lucky. - DONE
-Something better than a tent to sleep in or at least a better sleeping bag.
-Steering upgrade
-Stiffeners welded in
-New belt - DONE
-Install starter drive - DONE
more crap to add:
- trans pan gasket
- pinion seal on 8.25
- oil change
- axle shaft u-joint
- trans pan gasket
- oil change
need to make my jeep run. I think it needs a fuel pump.
Put tire back on
Rebuild spare rear driveshaft
Install rear driveshaft
Fix the cigarette lighter for the CB
Scrounge up a better spare - Got tire, need wheel
Double check fire extinguisher and first aid kit
Maybe add a new rear hatch (currently strapped on)
Load jeep and spare parts.......atriot:
