This is my day trip wheeling setup. Tools don't really change much between this and my multiday packup. Just added stuff for camping and what not go in.
20lb CO2 tank. And the black bin hold my tools. The soft bag on top is cooking/emergency overnight gear. Stuff gets added to that when I do planned overnights. But I'll just post about the tool box.
Top to bottom left to right
-15ft Goodyear air hose and Campbell Hausfield inflator/gauge
-30 ft 30,000 lb tow strap
-"Mobile Power" jumper pack with built in 400 watt inverter, 12v outlet, and compressor. The small bag ontop of it contains all the power adpaters. You can charge a vehicle though it's power port or I can hook it to my Jeep when running to charge it back up when running the trails so it's fully charged for camp site use.
-Stanley Wal Mart tool kit. Has so far had most of what I need to work on the Jeep especially with the weird Metric/standard hardware the XJ has had over the model years.
-Chicago Electric (Harbor Freight) Drop light powered by Jumper pack
-Tire worm tools and valve core remover kit with spare valve cores and spare valve stems
-General Purpose First Aid Kit. A smaller "blowout/immediate action" kit is in my day bag which goes with me at all times.
-50cal Ammo can with snatch block, shackles, tree saver strap, and a spare axle shaft u-joint and drive shaft u-joint. I really want to add a ball joint press to this getup to make u-joint changes way easier.
-Breaker bar and long extension that won't fit in my tool kit
-Craftsman 12V LiIon drill. Usually carry the charger with me on multiday trips and run it off the inverter if I have to.
-Electrical parts kit with various connectors fuses, test light, spools of red and black wire, a cheap multimeter, and a spare Crank position sensor.
-Winch Control
-1lb Rubber mallet. A 3 lb mini sledge usually goes with this as well but I've only got one right now so it's in my shop tool box.
-Food for emergency overnight stays. A TOTM (downsized MRE) and a can of random soup from the cupboard.
-Fiberfix wrap. This is the same stuff the use to make casts with now. Very easy to use and is very strong. I've used it to fix broken shift and brake levers on motorcycles after they've been dropped.
-Set of TiN drill bits
-Speakers for Iphone.
-Tool kit bag which has it's own break down below.
This tool bag rides in the plastic box and carries all of the misc stuff that doesn't have it's own case/bag ect.
-Soldering Iron and solder
-one spool of .20 safetywire and one spool of .40 safety wire. My .32 roll is lost to the gods somewhere. Need to order a new spool.
-Electrical/crimping pliers
-Magic Eraser. Not sure why I carry this in the Jeep. Really need to move that to my shop tool box.
-Tape Measure..........for measuring suffs
-various socket adapters
-Quick Steel and electrical tape
-Safety Wire pliers.
-Large and Small vice grips.
-Zip Tie gun
-Attachment to turn a 2 liter bottle into a makeshift shower. Works pretty good actually.
