95cherjustin
- doylestown, pa
WANT TO PUT SYNTHETIC IN DIFFS AND TRANSFER CASE 95 XJ 4.0. What brand is okay and weight? Royal purple or mobil 1
MOUNTAINGARAGE said:I use Mobil1 or Redline 10W 30 in my NP231's
ATF evaporates out of the vent tube over time.
why would you put different weights in the front and rear? is it because the rear is under load more often (unless you have a trailer queen)Mudderoy said:I used Royal Purple 90w front 140w(?) in the back.
maybe it "evaporates" out onto your driveway... if it's got a leaky seal:moon: :roflmao:MOUNTAINGARAGE said:I use Mobil1 or Redline 10W 30 in my NP231's
Gravesdiggerxj said:maybe it "evaporates" out onto your driveway... if it's got a leaky seal:moon: :roflmao:
ATF is spec for the 231
using synthetic will definitely quiet down that chaineace:
DanMan2k06 said:It's usually about a quart, definitely less than 2. Get a big gallon bottle and it will do both with ease.
Edit:
dana 30 front is 2.5 pints (1.25 quarts), dana 35 rear is 2.5 pints (1.25 quarts), 8.25 rear is 4.8 pints (2.4 quarts).
