jooper
- in a box by the river
As you've already been told, there is no such thing as a Dana 30 rear axle.
Yes there is. Just not in jeeps.
how bout ya give him a break Deft, he probably goes wheelin when he's invited.
haha well said..
Ill try not to be an ass, but do some research. You are going to run into a lot of problems if you just start throwing on 35s and stuff like that without thinking it through. Im 1200 posts through and JUST NOW stepped up to 35s.
First off, you dont have 2 dana 30s, you have one and its up front. The rear axle in your jeep is either a d30( you mean D35) (dont even think about putting 35s on that) or a 8.25. If you have 297/760 series front joints and non disco axle or 29 spline rear shafts in the 8.25 (if that is what you have, 97+) then that will help, also if its not a 2000 or 2001 then it will have a high pinion dana 30, which is also good. We need more information about your car, and again you might not want to step it up just yet.
if you're on a 35 rear, that does not mean you can run 35s safely... just so you can't say no one told you.
35" tires on a D35 rear is sketchy at best. If you keep it open (unlocked) and are easy on the go-pedal, it may last awhile. The problem being that muuch tire weight and leverage (not to mention traction) is more than the D35 was designed to handle. I do know a couple of people who ran 35"s on a D35, and it ended badly. It's really just a matter of time with that axle. Look for a Ford 8.8" out of an Explorer or a factory D44 or Chrysler 8.25" to swap in.
The front D30 can handle 35"s if you upgrade the shafts and u-joints to high alloys/aftermarket such as Yukons, it also helps to use a thick aftermarket diff cover to stiffen the pumpkin.
This is all i could find. I also hurd a Rear 30 was use in some Frod car or truck.Waiting for a Link!!!! I'm not saying you are wrong i just haven't heard of it!
i hate to argue bout the stregnth of a d35 but i have mutiple buddies who have run 35s on em in wrangles no problems and one had a detroit locker and the replacing only what breaks is good advice
i had a cherokee with 33s 4:10 gears and a locker beat the crap out of it just like evryone i no runnin 33s and 35s on em only thing that broke was locker only other person i know with d35 that broke it was the spider geargood for you and youre friends, i know twice as many who have blown up D35's on 31's or 33's
