Weird noise at 40-60 mph, no idea what it is
coolusername
California
Okay, so I'm at my wit's end and need some help. A couple of months ago, my 2001 XJ started making a strange noise (coming from the rear of the vehicle) at around 40-60 mph. I took it to the mechanic, and he thought it was the transfer case. We changed the transfer case, noise still there. We noticed that if we take out the rear driveshaft, and put it into 4WD (so the front axle is driving the car), the noise is gone. So we thought it was the rear axle, and that was replaced. Noise is still there. We also rebalanced the rear driveshaft, noise still there. We're running out of parts to change, and are thinking it's the transmission. Could it be anything other than the transmission at this point? Linked is a video with sound of the noise, does anyone here have an idea of what might be causing the sound?
https://imgur.com/a/GLTknq6
Other pertinent information:
- Jeep has a 3.5" OME lift
- 1 ton steering kit
- Adjustable control arms
- Transfer case has been dropped
- Exhaust hangers have been changed
- Issues started a few weeks after 2" front spacers were installed to level out the car
Full invoice of all the parts installed: https://drive.google.com/file/d/1W50kgvT6UIuz_qiM9aR5G5z47qw1My1Y/view?usp=sharing
In all this work did you not put in new u joints? How is the slider on the front driveshaft? Mine has a bunch of slop and vibrates over 60.
The first thing I would suggest, is you find a more skilled/more honest mechanic. As you have discovered, randomly replacing parts without employing basic diagnostics gets expensive real fast.
Since the most recent modification/change/repair is 2" front spacers, I would look at the front pinion angle, and the front drive shaft u-joints, the slip joint condition, and the centering ball condition.
I will suggest that at 3.5" of lift 2000-01 XJ's will benefit from an SYE. Transfer case drops are hard on the engine mounts and cause excessive front drive line angles.
x2 on u-joints. Try taking out the front shaft and going for a spin. You could jack the back end off the ground and run it up to speed to see if it's related to the front spinning as speed too.
