ZoranZ
- Beacon, NY
Hi all...
Been a while since I've been on here, haven't had any issues with the old XJ until I decided to be brave and change my serpentine belt on my 99 XJ Sport 4.0. Pretty simple enough right? Well, the 4 simple screws to remove the electric fan and the fan guard were all rusted and stripped. So here's my problems.
1. Couldn't remove the screw for the electric fan closer to radiator cap (drivers side), plastic broke while removing. The screw is stripped so I'm going to have to drill it out. I"ll probably epoxy a piece of plastic to the fan and drill a new hole to hold it in place. The other screw and plastic is intact. There's not much movement from the drivers side anyway. That or I could just drill another hole somewhere where the plastic is ok.
2. While removing the fan I didn't disconnect the hose that goes from the radiator to the reservoir and broke the little plastic piece the hose attaches to. Does that mean I need to buy a new radiator to fix that? (see photobucket link for pictures)
The good news is, once I broke, I mean removed everything I was able to get to the pulley and loosened it up so I should be able to get the serpentine belt in there in the morning. Just sort of SOL right now with the pieces I broke until someone gives me some info, tips.
http://s358.photobucket.com/user/zoranzam/library/99%20XJ%2040%20%20serpentine%20problems
Thanks in advance folks!
