OK - one more time for this:
1984-1986 - Delco 12SI with internal regulator.
1987-1990 - Delco CS130 with internal regulator
1991-2001 - Nippondenso open-frame (various sizes) with external regulator circuit in the PCM. This covers OBD-I and ODB-II - and it's pretty much a Chrysler standard these days (they quit using their own alternators years ago, and use either ND or Mitsu units instead. Some Bosch on high-output units.)
Since you have an external regulator, and they're actually not known for going bad, you have a few more connexions to check.
1) Go ahead and remove the PCM connectors (the 60-lead "harmonica" plugs) and blast them out with a good dose of electrical contact cleaner. Brake parts cleaner will serve in a pinch.
2) Check that all three (maybe four) of the wires going to the back of the alternator case have good mechanical contact, and that all of the ring eyes, studs, and nuts are clean. The battery output post takes an M6-1.0 nut, and I think the two field contact studs take either an M6-1.0 or M5-whatever (I don't recall the pitch for the M5 thread) nuts. A small brass brush works wonders - if you don't have access, use an old toothbrush and cheap toothpaste (rinse with contact cleaner) on the posts and a regular old eraser on the rings, so you don't remove material. Reterminate as required.
There will be three leads (output, field power, field ground) and may be four (ground lead attached to the alternator case.) Make sure all of the rings are clean, all of the fasteners are clean, and all of the terminations are good.
Check the main grounds - one will be back by the oil dipstick bracket (above and aft of the distributor. Clean it well - it tends to get oily) and the one on the fender liner (clean the contact patch on the chassis down to bare metal and apply corrosion inhibitor, like Gardner-Bender Ox-Gard. It's what I use, it's what I recommend, it's what I sell. NB: WD-40 has no RPT no valid electrical uses, despite what the label on the can or the display text may say!) It won't hurt to give the engine-to-firewall ground a seeing-to as well, but it's not as critical as it is on RENIX.
Verify any suspect voltage readings with a "known good" multimeter test, reading taking at the battery posts and/or at the alternator output post (best to check both - that can point something up. They should not differ by more than .1VDC - if they do, you have a dirty connexion somewhere.)
A fairly standard test to check the electrical integrity of the main connexions is to put one voltmeter lead on one part of the connxion and the other lead on the very next part (for instance, one on the battery post and the other on the clamp) and take a voltage reading - it should not be more than .1VDC difference. The same thing can be done using an ohmmeter - but remove power from the circuit first (not more than 2 ohms.) If the reading exceeds those specifications, take the connexion apart and clean it. Repeat for all of the exposed bits you see. The positive mains connections can be readily checked for a voltage differential - don't neglect the PDC to battery cable posts and such (post-nut, nut-lug. Two tests there.)
You can use corrosion inhibitor on most of the mains connexions (particularly the alternator, since it's low,) but make your own for the battery. Use four fluid ounces (one-half cup) of petroleum jelly and one and one-half tablespoons of baking soda (not baking powder!) For ease of mixing, heat the PJ gently in a double boiler and stir in the soda. Pour into an amber jar (if available) and paint on battery posts and clamps using an "acid brush." Discard the brush, store the remaining jelly in a cool dark place. Reapply at least annually, or after washing the engine bay or soon after deep-water fording. Likewise corrosion inhibitor on other connexions.
