TRAILREADYXJ
- Raleigh NC
The module we carry is $150, and I'd expect $50 or more labor since wires need to be run into the drivers door. This isn't bad at all on an XJ, but lots of shops (ours included) base installs on a flat rate.
You will need to replace those switches on the rear doors and hatch, the sensor wire is tapped into the dome light trigger. XJs use a negative trigger, so a standard pin switch will work on the doors. The shop you are going to should have some lying around. The only difference may be thread size and wire connector (simple 1 wire hook up). I haven't messed with a hatch switch, but need to since mine doesn't work either. I believe it's in the latch inside the hatch.
