cherokee chuck
- freeland,wa usa
You're not helping me work on my Jeep buddy! Buy a new $3 bolt & Loctite it, if the track bar is your problem. You might want to remove your track bar without a grinder some day. The heat from welding won't do the bushing any good either. Make sure you use the original type flag nut also.:roflmao:XJ AV8R said:...and then tack weld it so it won't move anymore...if this is your problem, that is.
