- Virginia City, NV
She ready to rock. Didnt end up getting to the winch but ill get that swapped out in between reno run and sierra fest.
Enjoyed wheeling with you again.RenoRun2021 was awesome. This chassis is on its last legs but man does it work well. I need to pull the windshield and replace it with something. Im leaning towards plexi but not sure.
As for the windshield replacement, look into a product called Margard 10 (MR10). Its similar to Lexan but is scratch resistant. I know someone who replaced their glass with this. I don't know if it is expensive or not.
That is of great help to me. No more agonizing over welding a truss. I will just spring for an axle bracket kit and the tubes then I will be good to go.
I saw online a wire harness kit for the locker that I need to get unless I can get connectors then make my own harness.
Great info my friend.
GordoSmasho, Back at you again after almost 2 years.
I am finally getting my Rubicon D44 together to put under my XJ. I have or identified everything I need except the track bar and drag link. What length did you use for both the drag link and track bar. None of the regular suppliers have any idea what is needed. I know I will have to re-work what I have but, were do I start?
So for the drag link I customized mine. I shortened the currie one i bought. But many manufacturers will build you a custom length unit. I would put the axle under the rig and measure.
As far as track bar i put an xj bracket from rustys. I out it in the xj location on the axle so i can just use an standard xj track bar.
You need assist with those big tires if you've blown 3 PS lines in a year. box is working way too hard trying to move the 37s especially when the front is locked.
No snow? How far in did you guys go?
