winterbeater
- Royal Oak, Michigan
So do you have the 12 V going in to the injectors?
just go test the cps(crank) real fast.i didnt read all of it, did you have spark?Its gotta be an injector issue. I haven't done anything to the Crank Position Sensor, just the Cam Position Sensor. I am done F*ing with this thing outdoors when its 5 degrees with a negative windchill.
Run position should give 12V
