Rockhound
- Pensacola, FL
anyone that has any thoughts please send them.
recently i aquired a 91 XJ that needed an engine. i decided to swap my 4.0 out of my built 91 into the new one. have spent the entire weekend pulling the engine and getting it ready for it's new body. heres the list:
pulled the oil pan, cleaned, replaced seal, reinstalled
pulled the valve cover, cleaned, replaced gasket, reinstalled
while i had the valve cover off i took the liberty of cleaning the top of the head as well. i had the shop vac in one hand and a flathead in the other sucking up what i scraped, as it was scraped
pulled the intake and header. same thing as head, brushed and sucked.
we were very careful the whole entire time making sure NOTHING fell in the engine.
rplaced freeze plugs, replaced flywheel and cover, engine turning very freely
got engine back in, bolted back up to torque converter, have not attempted to turn crank since that time. got everything reconnected. all new fluids, put in some 93 to get it going. it honestly sounds like there is a masonry nail between a ring and a cylinder wall. put my torque wrench on the crank and gave it a go, not nearly what it should have been. it does not make a bit of sense and i am out of ideas. the tranny is unproven, could there be some possible link?
PLEASE HELP!
i will be on all night and i may have left something out.....pretty pissed and need to smoke a cig but i had to wait to get this posted. you guys are awesome. :cheers: TIA
Jon :smoker:
PLEASE HELP!
Jon :smoker:
