- Bakersfield, CA
BillR said:What I've done (and it FEELS like it stiffened the body up) is:
rock rails, tied to the frame rail and pinch seam
RE drop brackets and braces; ties the LCA mount to the crossmember
HD front and rear bumpers, Mopar hitch in rear, both tied to "frame"
C-ROK plate at the steering box, and a MORE steering brace to the other side
RE HD trackbar/mount, with the optional brace to the other side
Not quite a cage, but it seems to be effective in combination...
Bill, I had all of that except the drop brackets and braces, and I did my own steering box frame plating (before C-Roks came out). Mine still cracked all to pieces. When I took off the rear bumper the rear cross member was cracked around nearly all of the bumper mounting holes.
Everything helps, and tying the control arm mounts to the rear spring hangers is a good thing to do. A couple of products do this, and there have been many good comments about T & J's stiffeners. Do what you can, but the only real way is a cage.
My experience is that nearly every time I stiffened up one part of the frame, something else cracked or broke off soon afterward. Here is an example of the most recent time. The bottom tube running to the end of the bumper was already there, but I added the upper tube and grill hoop, and the triangulated tube from the A pillar to the forward tube.
This broke on the very next trip, and you can see that the track bar bracket is thoroughly boxed, and the frame is boxed from the front crossmember to the motor mount.
By stiffening the whole front, which was the goal, now the frame around the track bar mount was left to flex on it's own, and it gave up the ghost to the 37's.
A new track bar mount brace is going on, the the steering box brace is going back on, now that the whole front is more rigid. I wasn't running either because I had previously ripped the track bar mount off while using a cross brace, and I ripped the steering box off (with the frame plated) while using a steering box brace. When the box ripped off it didn't hurt the frame, just broke two of the bolts and one of the bolt tabs on the box. That one really pissed me off, since it was a good Tommy Lee box less than a year old.
My point is to try and stiffen things up evenly, or the stress is just transfered to the weakest part. Not easy to do, but something to consider.
