Ok here is the answer for you guys
Take a look and the spring perchs on the axle and you will see they are at different heights!!! The left side is nearly an 1" higher to clear the side the the diff housing. Why in the hell the right side was not just made higher to match is beyond me ??? I just added a 1" spacer to the top of the coil that I made to even it up. See my site if you want to do the same or use a couple of extra coil isolators. You will also see there how to centre your axle with the re-drill method.
www.go.jeep-xj.info
www.go.jeep-xj.info
