- Salt Lake City
but does that make a wheel spacer a ticking time bomb? XXXX no. but it's also not 'identical', theres an extra peice of metal in there.
If you are referring to the previous post, he didn't say the set up was the same, just the leverage. The leverage on the bearings and lugs is the same. The risk factor in spacers IMO is just that there is an added point of potential failure. As long as the bolts/lugs on both the spacer and wheel are properly torqued and checked routinely, this should be a failure that never happens, just like with normal lugs. I opted away from spacers mainly because in order to check the torque, the wheel has to come off. When I want to check my lug torques, I prefer to just walk up to it and check it.
