tealcherokee
- CT
czb83 said:I have them on my computer. If someone wants them, or wants to host them then send me a PM with your email. Its 11 pics, about 1.5MB total.
i can host em [email protected]
tealcherokee said:i can host em [email protected]
I know with my car I was really suprised at how much hotter it was in the engine compartment, and I have an air to air front mount. So I think increased is an inevitability, but wrap would help right? I bought some wrap but have not messed with yet. I also bought a turbo cover too which are not big bux at Jegs/Summit.I built a turbo kit for my xj a while back and I took it off last summerI ran 7psi the horse power gain is there but parking a turbo under the intake makes way to much heat and it suffers for it in the summer I ran without an intercooler and that was a mistake you dont get unuff air flow to keep the turbo cool and the charge air will easly see over 200 deg Intercooler or sprayer system is a must I was seeing heat in such excess under the hood that I melted my clutch line from 5in away and I insulated everything that was near the turbo also had my fuel line unmold itself from the steel tubing too much heat.
BBeach said:Thats an odd location...must be a lot of exhaust routing if its a turbo. And I dont see a belt so its not gonna be centrifugal.
tealcherokee said:its the crap o matic 505 performance kit. uses 3/4 of the stock exhaust. by the time the exhaust gets to the turbo its prolly 100 deg, im surprised you even need a wastegate for the 6psi that kit pushes..... freaking junk
WheelinJR said:not to nitpick, but that 6psi is controlled by the wastegate, so that statement doesn't really make any sense. Yes you would need it. If you tried to run without one you'd be seeing alot more than 6psi. I'm thinking I'm reading just a little too careful and you meant blow-off valve. Supra guys like to use that trick of block plating the wastegate to see 35-45+ psi on the dyno for bragging rights.
While it does use a U-pipe to route the stock manifold over to the passenger side, which might not be the most efficient design, there are many much worse out there. STS uses that design that sits the turbo at the back of the vehicle, creating the need for return oil pump hardware and probably alot of lag. I can't say much on their quality of materials (not design) surviving or failing. Personally tho, I think for what they've designed, their pricetag of over $3000 is way overboard.
Still I think the 505 original TJ dyno showed a 6psi result at 92hp gain over their baseline dyno, and 104lb-ft gain, could be worse...still not worth the money though.
tealcherokee said:i was being sarcastic about the wastegate, saying it was SOOOO inefficent that it could bairly make the 6psi..... btw, 6psi into a 190 horse motor NEVER equals 92 horse.... let alone not intercooled 14.7+6 = 20.7/14.7 = 1.4
190*1.4=266
268-190 = 78 gain.... at best
a setup w/ a shorter exhaust will make the turbo more efficent, more efficent = cooler air charge, intercooler = much cooler air charge = same power at lower psi (because in reality that turbo is prolly doing enough work to make 12psi if it were mounted w/ a shorter manifold)
Pro Stock JohnI might have missed it said:You would use a FPR(fuel pressure regulator) with a pressure gauge. Set the base fuel pressure at idle. As the boost goes up each 1psi the FPR will increase Fuel Pressure 1psi
jforse said:The manifold length in that setup is not going to matter. The wastegate is what controls boost. The Turbo would make in excess of 30psi if there were no wastegate there. At 6psi the Turbo is not working properly. Far below its efficency range. 6psi into a 190bhp engine can produce that amount of power. Power gained is going to based on displacemaent of the engine, fuel system, fuel type, ambient temperature, and a multitude of other factors. (I dyno tune turbo charged cars for a living)www.archerracing.com
That setup does look bad though. It looks as though they are going the route of most Turbo Honda owners. Way to big of a Turbo at way to low of boost.
