cj7jeeps
- St. Louis Mo
Ok, did some wheeling today hit some deep mud pits and more water than i would have preferred. My buddy and i both had out xj's out playin in this stuff...on the way home..both of our alternators shot craps within minutes of each other...got mine fixed first then his...now i have a new little issue...the transmission is not wanting to shift through the gears...running about 3,000 rpms at 20 and wont go into any other gears....let the thing set and idle after hosing it off a bit under the hood...its shifting now but still erratic at times and doesnt seem to want to initally shift from first it hangs up i guess you would say...any one have this happen before??? Don't know for sure what i should look at TCU? TPS?? Now the orange check engine light is on as well...I'll get that checked out today but still any advice you have is appreciated...thanks
