txredxj
- PerrytonTX
i have a 350 trans 4wd and i would like to know what my options are as far as what i can use with the driver side output. i would like to do this on a budget so i will most likely hunt the junk yards.
txredxj said:i would like to do this on a budget so i will most likely hunt the junk yards.
jmop said:2x on a Jed's adapter. Thats what I went with as well.
Looks like he has a new design so even after you weld it you can clock it some.
http://www.jedsmachining.com/541397.html
ashmanjeepxj said:Can you run a drivers side drop t-case behind the mad rooster 231 box?
The box keeps some of the t-case that sticks out on the drivers side.
a ford 205 behind it has the DS front output further form the t-cas then a flipped d300. a D300 the frount output is pretty close to the tranny and doubler might not fit...
has it been done with DS drop?
