xj92
- Junction City, KS
I've tried RE HD, RE1600, Teraflex, & custom. Here are my thoughts:
RE1600: bent real easy when I got in a wreck, I don't care for the single shear design, and if feels real light weight.
RE HD: best overall design along with the TNT setup, but when I had it on mine when they first came out it hit the diff cover (I only had 3.5" of lift). Haven't tried the bar since but haven't heard of anybody else having the issue of hitting the diff cover, so it was probably something that was corrected.
Teraflex: Best except for the TRE on the body end. The entire bar is solid stock with a beefy adjustment sleeve so you can adjust it without unbolting either end, and it is rounded to miss the diff, not just straight sections with a few bends.
Custom: When the TRE died on my Teraflex bar, I chopped it off and welded on a RE small superflex joint. I then put on the RE bracket & brace. It has held up for a few years now with no problems.
I like TNT's design only if you're going to move your axle forward an inch or so. I also wish TNT had a brace going across to the other side of the frame rail like RE. That was the deciding factor for me.
