4xBob
- Prince George, BC, Canada
By drifting, I take it you mean your jeep wanders in stead of holding one direction. This is a result of loose steering connections....could be track bar (likely), or worn tie rod ends (next most likley), ball joints, or control arm bushings. Get under the front streering components and watch each joint while someone saws back and forth on the steering wheel- look for slop, if both sides of the connection don't move togther, tightly connected, then you have a loose fitting. Replace those- that is where the wander comes from. My 1990 (owned since new) is on its third track bar, tierod ends have been replaced either two or three time, ball joints once, and control arm bushings once (I don't like the poly bushings- too harsh). The control arm bushings probabaly didn't need replacing. The steering gear is now worn to the point where I get ocassional death wobble (extreme shimmy), so it will be replaced with a Dodge Dakota box next. Not too bad for 260,000 km (162,000 miles) and 18 years.
