METAL MONKEY
- severance, co
Lincoln said:Fuel90, did your axle have the lever actuated e-brake or a cable running into the backing plate like a stock axle? How did you make it work?Lincoln
i have two cables to the back plates like stock. the cables were way long, so ended up cutting off what i didn't need and then looped the cable through the stock e-brake bracket. then i used two cable clamps on each side to hold it all together. works great!
as for finding spares, i feel your pain. i have a pdf parts list, and you have to know every stinking little detail of what model the axle came from. if you don't, you run the risk of getting the wrong part.
