Jonner
- Charlotte, NC
Hi all,
I've begun the serious search for a good corded-drill. Brands I'm looking at are probably Milwaukee or Dewalt.
For versatility I'm leaning towards a 3/8" and for reliability of use (and torque) I'm looking for a keyed chuck. I need a corded drill because I don't want to deal with cost and inconvenience charging batteries. I also am looking at 5.5 amps or more and I want it to last. Budget is probably $130 top end.
This drill will largely be used for drilling up to grade 8 rusted bolts (think: transmission crossmember bolts, shock bolts, and possibly leaf spring bolts that won't budge).
I have two main questions? I've seen 3/8" drills range anywhere from an 850 RPM max to 2800 RPM max. I'm unsure what my needs will be for predominantly hardened steel.
Also unsure if I need a 90 degree handle or just standard pistol grip?
This is my first real venture into fixing broken bolts (I've sheared one tranny crossmember bolt off so I'm invested in this approach).
Examples of what I'm browsing (probably in budget on Amazon):
---Worried about low Max RPM (1/2" might be overkill)
http://www.amazon.com/gp/offer-listing/B0000223HF/ref=dp_olp_new_map?ie=UTF8&condition=new
---Made in China and $180
http://www.grainger.com/Grainger/MILWAUKEE-Pistol-Grip-Drill-6KW90?Pid=search
---Not keyed. Pricey at $155. 2500 rpm & pistol grip.
http://www.grainger.com/Grainger/MILWAUKEE-Pistol-Grip-Drill-6KW93?Pid=search
---$145.
http://www.grainger.com/Grainger/DEWALT-Pistol-Grip-Drill-4LF70?Pid=search
---$145.
