freddytran
- Arlington, TX
I tried searching but found nothing similar. Has anyone had the same problem? Solutions? I got a beat on some super cheap 3" Rancho shocks so I decided to do a 3" budget lift (3" steel spacers in fron adn 3" blocks in the rear). After installing the blocks, the rear swaybar/stabilizer rubs on the inside of the tire. So I just removed the rear swaybar.
Similar problem in front. The front swaybar is too short now so I removed it as well. Obviously there is much bouncing and steering slippage making the Jeep rock left and right. I can;t go over 55 MPH. Any help would be greatly appreciated.
Or should I just remove everything and go back to stock?!?!
