tudorXJ5sp
- Virginia
LOL!
everytime I have to get into wifes truck, I try to turn key as I attempt to push down invisible clutch, & I usually make it half way or more down before my brain catches on its a stinking automatic.
the only gear patterns that get me are on a MGB, where R is beside 2nd, but without a lockout, so if your jammin' hard through the gears, & hit a tight corner & need to go to second, I will usually scrape (grind) reverse, & let go & then pull back to 2nd, where on a old air cooled VW, you have to push shift lever down to engage second, so you can jam away & not worry. I was test driving a souped up MGB recently, been a few years since I drove one, & debating on picking another up..... I still have my first one which is now a parts car, & have owned 6 during my lifetime.
one of my favorite shift patterns, is straight forward & back, 1-2-3-4 then to upshift you slam it forward,to third, then pull lockout to go to second, & if you release next shift is back to third, if you keep lockout pulled then you get to first. how sweet!!!!!!!! I may do this to my old 64 Impala, that I have owned since the late 1980's.
