I asked Montana Fab about that (can't remember the guy's name - extremely friendly and helpful though) and was told it wouldn't be possible due to the logic controlled by the knob itself... Not sure of the specifics, but you may want to give them a ring and they could probably break it down for you. I asked about simplifying it to a simple push toggle button on the shifter (just to lock it into 2 - never had a problem with needing to keep it in 1), but it'd be worth asking him about.
Interesting, and I will definitely be giving them a call in the next few days. FWIW, I've been trying to persuade OTRATTW into doing a run of the rocker switch face described above, but the minimum run that Carling will apparently do for them is a quantity of 250. If there's something that knob is controlling other than just a simple on-off-on action, this may make doing that unrealistic.
I'm still debating on this point - the main reason I'm steering away from a locker of any kind in the front is to avoid sudden shocks or excessive strain to the drivetrain. I'd rather find a way to get un-stuck than blow an axle shaft or U-joint on the trail (the goal is to minimize the risk of *any* breakage).
Understood - and this is definitely one reason why I wasn't completely knocking the front LSD idea; it certainly does provide useful additional traction in some circumstances. However, I haven't yet been able to come up with a situation where I can quantifiably say that it's absolutely superior to the alternatives (4LO, a little more gas, better line, etc.). I also have a suspicion that it may be introducing some drag into the driveline at times that's hurting fuel economy slightly, but that's really just a suspicion at this point as I don't have any numbers to put to it.
My one consistent gripe has to do with using it in 4FT: steering grab. I like being able to turn around on the trail, and use 4FT regularly in lousy weather. Depending on the surface I'm driving on, the LSD can kick unexpectedly in with the steering at moderate lock, thus negating the advantages of having a centre diff. It doesn't happen all the time by any means, but it always seems to kick in just when I don't want it to. Just mentioning it because I'm running a 242 as well, so figured I'd pass it on.
The only reason I'm interested in a modified Backbone is indeed because of the stock bumper/caps - I like the idea of a slight crumple zone remaining on the front of the car just in case I drop on the front end too hard or am involved in a low-speed collision. The FbG (and other similar bumpers) scare me purely because of how strong they are - a small fender-bender could end up being more along the lines of a frame-bender with these things.
Copy that, and if my stock bumpers and end caps weren't already dented and barely hanging on anymore, I'd probably be right there with you
I'm drawing up a few sketches tonight and will be meeting with Mark sometime tomorrow morning. He has a few minutes to shoot the breeze about it, so we'll see what his thoughts are (as I may be overlooking some crucial details). I'll definitely let you know what pans out.
Please do; I'm very interested in how this all shakes out.
