After running the three shock suspension setup for the past few weeks, I finally picked up some replacement shocks via Don at Gresham 4WD.
In an effort not to kill these shocks, I immediately set out on building some rear bump stops. Plan was to build some extensions off my RuffStuff Spring Plates. After seeing northwestxj's rear bump setup I stole his idea of using 2x1 as a bump pad.
Capped the ends for no reason.
Tacked in place. Done with Part1.
While cutting apart Dellstopjeep's Red Mustache Ride I snagged his front bump stop towers for an unknown project at the time. Well I decided they would be perfect for an extended rear bump stop in the rear. Wrapped some paper around them to mark out a square cut.
Mocked up.
Added some paint, and then reinstalled. Now when the rear catches some air I'll have a peace of mind.
After doing all this, now I really have the urge to put the shocks through the floor to gain some uptravel. Never ends.
Mocked up.
