DelmarvaXJ
- Naptown
Thanks man, exactly what I was looking for, personal experience and what works for you guys and how it might help me. thanks Also what lift kit is that, or did you piece yours together?
DelmarvaXJ said:Thanks man, exactly what I was looking for, personal experience and what works for you guys and how it might help me. thanks Also what lift kit is that, or did you piece yours together?
Just wondering what you just said, you really don't have a 5" lift, it's more like 6" or 6.5". Since you have the RE 4.5" which equals around 5" to 5.5" plus the 1.25" shackle.... Would I be wrong, I'm still new to this stuff, so I could be wrong...thanksrpraterxj said:That is the RE 4.5" short arm kit with adjustable upper and lower control arms, and the control arm drop brackets. I have ACOS in the front and 1.25" schackle in the rear. I am running Bilstein 5150 shocks all the way around.
FWIW, when I air down, I go to 12 psi. No problems with the bead and the tires stick pretty dang good.
I am very satisified with the drivability and off-road performmance of the lift. Now I need to upgrade the steering and brakes... coming soon!
Hope that helps!
When you get ready to buy, check out the vendors. They help keep this site running!
Thanks!
DelmarvaXJ said:Just wondering what you just said, you really don't have a 5" lift, it's more like 6" or 6.5". Since you have the RE 4.5" which equals around 5" to 5.5" plus the 1.25" shackle.... Would I be wrong, I'm still new to this stuff, so I could be wrong...thanks
DelmarvaXJ said:Thanks for your input, so your saying that I will regain my stock driver ablity from upping the gears from 3.55 to 3.75 or 4.10?
DelmarvaXJ said:I keep hearing that RE LA's get bent from hitting rocks, which I won't be doing.
Georgia Mike said:If you're not gonna be doing any rock crawling, don't worry about bending the RE long arms. Besides, you've gotta be doing some pretty major rock bashing (or need some driving lessons) to bend 2" DOM with 1/4" wall thickness, which is what the RE long arms are made from, IIRC. Especially under a lightweight rig like an XJ.....
OMG!!!You dont get a choice!DelmarvaXJ said:Reverse rotation, or standard rotation gear sets?
RE LA's are made with chromoly!Georgia Mike said:Besides, you've gotta be doing some pretty major rock bashing (or need some driving lessons) to bend 2" DOM with 1/4" wall thickness, which is what the RE long arms are made from, IIRC.
