This should not be used fro cruise control. What those are used for is to keep the RPM constant while going over rocks off road. Usually used with a manual transmission. Not for use on the road where it is not needed and is unsafe.
Ive been looking at this cause I really want a hand throttle for rock crawling. I was also going to use it on long trips to rest my leg. I expect it for xmas. But real cruise control is nice cause you can speed up and slow down with buttons!
Bad idea for cruise control, you have to make a conscious decision to return to idle, or change throttle position at all. If you're gonna use it for 5-10 seconds to stretch your ankle, I can see that, you're paying close attention. I wouldn't consider using it for more than that.
I had a hand throttle on my 94 for a couple of years. I found it wasn't all that useful with proper gearing behind a 5spd.
I have the RE one on mine, I doubt you could use it as CC anyways, the amount it moves the throttle is minimal at best. Like stated above not very usefull. I just use mine to get started while going up a hill (to get my foot off the brake and on to the gas with out stalling) I have played with it in the neighborhood and I can drive around up to 3rd gear but it starts to bog down after that and will do about 20mph.
