TheNerd
- San Diego, CA
... the more I think about it, the more apprehensive I get. I believe that the electronic mode select switch is located in a different position than the vacuum (front half of the case vs. back half). You will be able to plug the vacuum switch location, but I am unsure if there is a stock "hole" where the electronic switch would go on the older cases...
