jeeperjohn
- Temecula, CA
All differentials should be lincoln locked! :gee:
Yeah, 'cause those are "ultra" reliable. The air lines NEVER fail.
ARB's make me happy I got an OX.
Air lines fail due to Installation error! Not due to "an" air line just leaking.
That my friend is a crock and you know it. I've been around too many to know that is not true. Lines get pinched, crack and then leak, cables don't.
:confused1 SO its the air lines fault that it was installed somewhere to get pinched? Crack? the nylon line doesnt just crack. and if your a good installer / shop, you typically sleeve that air line and never have to worry about a thing.
Again, a quality install the First time will assure trouble free air delivery for over a decade.
And it's the cable's fault for being installed somewhere it gets pulled on and stretched? It's the same thing. :doh::confused1 SO its the air lines fault that it was installed somewhere to get pinched? Crack? the nylon line doesnt just crack. and if your a good installer / shop, you typically sleeve that air line and never have to worry about a thing.
I can see what he means about the cable stretching but I don't know about anyone else, but my shop compressor builds up moisture a lot in the summer from the heat and humidity. That right there you run the risk of rotting the bottom of the tank, getting moisture in the diffs, and you have to drain it. That seems like maintenance to me. With an OX's cable you keep it tight and greased. It's 6 of one, half a dozen of the other. They're both good in their own ways and both have their issues. You'll never get a perfect product.I agree. The only way an ox is going to pop out is if it is misadjusted or the cable is too short so its sheath gets stretched or it is bent/kinked, both due to improper length or routing.
I don't like the cable design because it is annoying to route but that has nothing to do with its reliability when installed properly.
I have heard that even with an electric shifter or an air shifter a cable is still needed. Is this true?
For the air activated method, an air chamber screws directly into the side of the differential cover, and directly activates the shift fork. No cable is used.
David Bricker / SYR
