timk578
- kodiak, ak
Ok so i have a problem ....i broke some teeth off my ring gear but still needed to drive it for a couple of days....so i removed the broken ring gear off the carrier cleaned out all the chunks and reinstalled...now i have my new ring gear and pinion...i wish that i would have used my shitty ring gear to to hold the pinion from moving when i try to break the pinion nut...ive tried the whole air ratchet with the a floor jack under the yoke last time and it took forever does anyone have a easier way to remove the nut .????? if not i will just go back to the way i did it before with the air ratchet...i know when i installed we couldnt get the cruch sleeve to crush with a 3/4 air ratchet...we had to use a pipe wrench and a huge breaker bar....help i know there has to be an easier way
