gorman
- South Africa
Does anyone know what the stock pinion/caster angle relationship is on a LP D30? I'm trying to find a way to measure my caster angle at home using an angle finder. The pinion angle is easy enough to measure, so I figured that if I know the relationship between the two I can calculate my caster if I know the pinion angle.
Taking a rough guess I recall the last time I had an alignment done, my caster measured around 6 degrees. The pinion angle I measured at 5 degrees, the one being positive and the other negative, thus the total difference being 11 degrees - does this sound about right?
