lazyxj
NAXJA Member #1310
- Los Angeles
As for a few of you Internet experts.... quit posting bs info. Electric fans do not work well on an xj.
High-end electric fans will work on tall radiators. The problem is our XJ radiators are very short and do not allow large diameter, high CFM fans to be used.
Small diameter electric fans never match the CFM capacity of larger fans.
Newer vehicles that use electric fans have systems designed to handle the high electrical loads.
Our XJs were not designed to handle the additional electrical load of fan and need expensive upgrades to the alternator, wiring, fusing and relays, a lot of extra stuff to go up in smoke, at the wrong time.
The stock mechanical fan is fairly foolproof as long as the fan clutch is checked out regularly.
Guess the choice to go electric or stay stock depends on how you use your XJ.
We regularly drive many miles off the pavement, in our trips around the West.
I want the drivetrain to be as simple, dependable and as near stock as possible.
When something does break, I want the parts to be readily available. Stock XJ parts are quickly available at any auto parts store or online.
Aftermarket fans, controllers and relays are not.
